Lenovo Lemon X3 (X3c50) - Snapdr 808 5,5" FHD 3GB Ram 32GB Rom 8/21MP Cams 3600mah VR Gläser Hifi
J
johndebur
neues Handy von Lenovo, das mit Kopfhörern und VR Gläsern verkauft wird. Presale Preis ist 2499 yuans (365€
支持接入VR设备 乐檬X3套装价曝光 mtksj
VR device supports access music lemon X3 set price
Because there are separate ways God broke the big-infested, many unpublished phone was exposed as the mobile phone industry norm, including a new member association upcoming music lemon - lemon X3 music .
From appears in the China International Exhibition to network, music lemon X3 basic information basic no secret at all, but tonight 7:00, Lenovo will play in Beijing, China director of the center for the sake of power, held X3 lemon called " and sound all come, "the new conference, Le lemon X3 additional information will be announced one by one. Prior to this, the price of music lemon X3 leaked in advance. Legend Music lemon pre-packaged version of X3 has quietly shelves, why is the pre-suit version of it? Because this version in addition to containing a lemon X3 music phone also comes standard with a VR virtual reality glasses and a HIFI headphones!
HIFI headphones feature not yet public, but from the VR glasses LOGO view, should be Lenovo and ANTVR launch products, this VR glasses can access music lemon X3, so that the latter turned to provide an immersive experience. " eye". Moreover, according to the contents of speculation Suite edition, Le lemon and ANTVR cooperation VR glasses and HIFI should all be a part of the new conference.
Outside surprising VR device can access the new features, the basic specifications of music lemon X3 came before complete and consistent, this new music lemon First to market a dual-4G version (internal models for the association X3c50), using 5.5 inch 1080P screen, 3G + 32G large memory and Xiaolong 808 six-core and 8 million / 21 million (SONY IMX230) pixel camera and 3600mAh battery, the system is Android 5.1 (VIBE UI). Sound part of the kernel, music lemon X3 will use Dolby Atmos technology, independent HIFI audio chip and dual front speakers.
We are most concerned about the price, including VR glasses, HIFI headphones Legend Music lemon X3 Suite edition pre-sale price of 2499 yuan, but if the launch does not Peripherals Lenovo music lemon X3 Standard Edition, is expected to price a lot cheaper.
Brooklyn701
Ja ich hoffe es. Denn das ist für mich leider ein totales K.O. Kriterium... Sonst ist es nämlich saugeil (Dual SIM vorausgesetzt). Vor allem für den Preis.
Sotair
Kaffes Nikotides
Wenn ich das recht sehe, sind die Tasten ähnlich wie bei der Vibe-Serie in das Front-Panel unterhalb der Anzeigefläche fest integriert (leuchten auf bei display on und sind auch nur dann aktiv). Also nicht wie z.B. bei LG G2 oder Huawei P8 / P8 lite als "richtige" onscreen-Tasten.
Ergänzend zum Eingangspost von @johndebur die verfügbaren Specs & Preise (Presale-Ende für 25.11.2015 angekündigt) der X3-Versionen aus dem CN-Shop von Lenovo:
"Einsteiger-Version": Youth Edition [X3_dipei] mit MTK 6753, 2GB Ram, 16 GB ROM, Kamera F/R: 13/5 mp
Preis: 278,41 € / 1899 ¥
Colour: Everest White / Black
CPU frequency: 1.3GHz
CPU: MTK6753 eight-core
Battery Type: Non-removable battery
battery capacity: 3400mAh
Battery Replacement: Replaceable
SIM card size: Micro sim card + Micro sim card
Network standard: Mobile Unicom Telecom 4G 3G 2G support
Network frequency: TDD-LTE / FDD-LTE / TD-SCDMA / WCDMA / CDMA 1x / CDMA EVDO / GSM
Dual card machine type: Multi-mode dual card
screen size: 5.5 inches
Screen Material: Corning Gorilla Glass screen third generation
Touch screen type: Capacitive screen, multi-touch
Resolution: 1920x1080 pixels
Screen Color: 16 million colors
Memory Card Type: MicroSD card
Front camera: 5 million pixels
Rear camera: 13 million pixels
packing list: Battery charger x1 x1 x1 data cable
ROM: 16 GB
RAM: 2GB
Body LWH: 154 x 76.5 x 9.3 mm (3.4 mm borders)
Series: Music lemon
Die Dual 4g-Version / X3_zhongpei aka X3c50
6-Kern-Snapdragon 808 mit 3GB RAM / 32GB ROM, besseren Kameras, Akku minimal größer
Preis: 366,37 € / ¥ 2499
Die "Full Netcom"-Edition [X3_gaopei aka X3c70] ist die 64GB-ROM-Variante der Dual-4g-Edition, ansonsten sind die Spec.s gleich
Preis: Preis: 439,67 € / ¥ 2999
CPU frequency: 2 * A57 1.8GHz + 4 * A53 1.2GHz with big.LITTLE technology, 6 cores
Battery Type: Li-Polymer battery
battery capacity: 3600mAh
Battery Replacement: not support
SIM card size: Triple two slot.Slot 1: Nano SIM card; slot 2: Nano SIM card or Micro SD card.The default is 4G mobile card slot; not hot swappable, plug card needs to restart the phone after
Network standard: Mobile / Unicom 4G (TD-LTE) / Unicom 4G (FDD-LTE), mobile 3G (TD-SCDMA) / Unicom 3G (WCDMA), mobile 2G / Unicom 2G (GSM)
Network frequency:
2G GSM: Band 2,3,5,8
3G WCDMA: Band 1,2,5,8
3G TD-SCDMA: Band 34,39
4G FDD-LTE: Band 1,3,7
4G TDD-LTE: Band 38,39,40,41
NW (2555MHz-2655MHz) CA: B3_C / B7_C / B38_C / B40_C / B41NW_C (Cat6) / B39 + B41NW (_C Mean Intra CA)
Dual card machine type: Dual card dual standby single-pass
Screen Material: Corning Gorilla Glass panel Third Generation
Touch screen type: Full fitting incell capacitive screen, supports multi-touch
Resolution: 1920 × 1080 (FHD, 1080P)
Memory Card: TypeMicroSD (TF)
Front camera: 8 million pixels, back-illuminated camera, F2.2 aperture, fixed focal length
Rear camera: 21 million pixels stacked (third generation BSI) camera, support PDAF rapid phase detection AF, 6P lens group, F2.0 aperture
packing list: Host × 1 (containing non-removable battery), travel charger × 1, USB cable × 1, three packs of card × 1, manual × 1, SIM card pin × 1
ROM: 32GB
RAM: 3GB
Body LWH: 154 x 76.5 x 9.3 mm (3.4 mm Borders)
Series: Music lemon
Auf einigen indischen Seiten geistert noch eine Single-SIM-Version des Lenovo X3 rum, aber auf den offiziellen Seiten von Lenovo India ist noch keine X3-Version gelistet.
Ansonsten scheint bislang nur Merimobiles das Phone in der großen Version schon zu listen, allerdings mit abweichendem Specs (s. z.B. Akku oder Maße) und einem Presale-Preis von ~ 356 € für die 64GB-Version
Quelle
wydan
infernalwrath
mir persönlich wäre es zu teuer (390 €).
das Xiaomi Mi4c hat den gleichen chip und kostet die hälfte, hat mindestens genau so gute cam, aber "nur" 2gb ram, noch ein nachteil, es hat kein hibryd slod. fairer weise sollte man sagen, das das MI4C das einzige mit dem chip ist, das so günstig ist.
Sotair
Kaffes Nikotides
Hallo @infernalwrath
Eine Rezension findest Du z.B. hier (Google Translate benutzen):
http://smartmania.cz/lenovo-vibe-x3-recenze-test-android-12829/?sc=1/
Unboxing & erste Eindrücke:
http://www.gizchina.com/2015/12/10/lenovo-vibe-x3-unboxing-and-first-impressions/
oder mit englischen Untertiteln als Video (sk)
Der Preis von 399 USD (ohne Mofi-Case) klingt gut für di 32 gb-Version - im Osten wird es vielfach eher um die 450 € gehandelt. Der von Dir verlinkte Händler sagt mir nichts, hat aber bei Ali erstaunlich gute Bewertung.
Viele GRüße
sotair
infernalwrath
Danke an euch für die Infos !
Teilweise soll Google Play bzw. google Services fehlen, und nur englisch und chinesich als Sprachauswahl sein....
hab ein Video über einen Lautsprecher Test gefunden, das klingt echt gut!
Sotair
Kaffes Nikotides
Ja, mit multilanguage custom ROMs sieht es noch etwas mau aus, aber das Gerät ist auch noch ziemlich taufrisch am Markt. Ich vermute mal (Kristallkugel-Modus an), dass sich da in den nächsten 1-2 Monaten noch was tun wird. (Kugel aus) Ich kann ja mal bei TeamSuperluminal anfragen, die die CM-Versionen fürs Vibe Z K910 und eine CM13 fürs Mi4c bereitstellen, ob es da Interesse gibt, CyanogenMod fürs X3 zu portieren. Kann natürlich sein, dass die Des erst den Launch der Android 6-Version von Lenovo abwarten ...
