Yotaphone Yota3 - Snapd 625 5,5" FHD AMOLED + 5,2" e-ink 4GB Ram 12/13MP Cams 3200mah dual sim
J
johndebur
neues Yotaphone , das Handy soll im Herbst erscheinen.
https://yotaphone.com/ru-ru/
YotaPhone3详细配置曝光 仅定位入门级 cnmo
YotaPhone3 detailed configuration exposure only positioning entry level
[ Mobile phone China News] YotaPhone is a Russian company to launch a smart phone , its greatest feature has an ink display that is back in the fuselage, in the design of the homogenization of serious today, it appears like a clear stream. It is reported that YotaPhone3 has recently held in the China-Russia exposition debut, is expected in September this year, the domestic and Russian markets, and now its specific configuration has been exposed.
  After Yota company only revealed that the machine will have 64GB and 128GB two different versions of the storage, priced at $ 350 and $ 450. Details, YotaPhone3 screen size of 5.5 inches 1080P AMOLED, the back of the fuselage ink screen is 5.2 inches, its carrying Xiao Long 625 processor, with 4GB RAM, 12 million pixels +13 million pixel camera combination.
YotaPhone3 debut
  It is equipped with 3200mAh capacity battery, battery life is good, in addition it supports dual card dual standby, run Android Nougat system. Overall, its configuration only positioning the end, but such a novel design of the phone, you will consider buying it?
ExUser 9209
heute häufen sich die Neuigkeiten zum Yotaphone3 oder yota3 im www. Soll wohl in den nächsten Wochen erscheinen........
Wenn da alles drin ist was drauf steht wäre das mein Favorit nach dem Elephone P9000.
Man wird sehen...........
Andycat
Ich auch habe ja schon das yotaphone 2..... ist mir zu klein...das 3er ist größer....mal sehen was der Preis so sagt
Gesendet von meinem Y6 Max mit Tapatalk
ExUser 9209
Die Vorbestellung startet am 5. September 2017 über den Onlinehändler JD.com, ausgeliefert werden soll das Smartphone ab dem 18. September.
.......golem.de...........
ExUser 9209
Kennt schon jemand jemand der das Yota 3 je getestet hat.? Obwohl preislich etwas uninteressant geworden täte es mich doch noch etwas reizen...
THX
