Gearvita
Xiaomi Redmi Note 5 4G Smartphone 4GB RAM 64GB ROM (Global Version)
Coupon: 64XMRN5
Price: 163.16€
● Visually Slimmer Appearance:
Wearable and anti-grease coating full metal body, anti-dirt, anti-scratch, anti-fingerprint, Silk smooth and soft touch, totally designed for your palm size, perfect in every detail, everyone will love it.
● Face ID unlock + Fingerprint Scanner:
Accurate Back fast press fingerprint sensor, 360° identification fast response speed, you can set lock and have a quicker access with more secure privacy.
● Amazing 4000mAh(typ)/3900mAh(min) power-saving battery:
Redmi Note 5 can last for a whole day continuously, helping you apping & gaming from day to night, and you'll never lose the important message/push, really a good choice for you.
● 18:9 5.99" FHD+ 1080P Display Shocking View:
High light transmittance and color saturation, power saving, especially for eyes protection.
● Qualcomm Snapdragon 636CPU Octacore:
Qualcomm Snapdragon 636 Octacore, 4GB RAM+64GB ROM, Adreno509 GPU, high efficiency of data processing, stable MIUI OS, which supports numerous convenient and funny APPs with smoother multi-task running.
● 12.0MP f/2.2 + 5.0MP f/2.0 2-REAR-CAMs:
Selfies look amazing with a 13MP front camera, you can record every moment of your happiest times with it.
● Lightning-fast 4G-LTE Network:
4G-LTE, WCDMA, GSM, nearly full global coverage, good signal platform, support 2*Nano-SIM or 1*Nano+1*MicroTF card max 128GB extended( Pls refer to the listed bands and check whehter the bands under the local operator works or not)
								Coupon: 64XMRN5
Price: 163.16€
