Ich möchte euch heute ein bisschen von meinem Spontankauf Cubot X16 berichten.
Da es bisher hier im Forum bzw. allgemein zu dem Gerät wenig zu lesen gibt hier mal mein Ersteindruck nach 2 Tagen Benutzung.
Zuerst die Technischen Daten laut Hersteller:
Model: CUBOT X16
Brand: CUBOT
2G: GSM 850/900/1800/1900MHz
3G: WCDMA 900/2100MHz
4G: FDD-LTE B1/B3/B7/B20
Sim Card: Dual SIM card dual standby(One micro SIM or TF Card + One nano SIM)
Service Provide: Unlocked
Color: Black + White
Cubot X16 System:
OS: Android 5.1
CPU: MTK6735A , 1.3GHz 64Bit Quad-core
GPU: Mali-T720
RAM: 2GB LPDDR3 800MHz
ROM: 16GB eMMC4.5 200MHz
Cubot X16 Screen:
Display Size: 5.0 Inch
Type: JDI AH-IPS.Capacitive Touch Screen
Resolution: 1080x 1920 pixels FHD, 440PPI
Screen Color : 16M Colors
Shell Material metal
Cubot X16 Support Formats:
Ringtones Type Polyphonic/MP3
Video Formtats MP4,M4V,MKV,VIDX,XVID,ASF,WMV,RM,RMVB
Audio Formtats AAC,MP3,WMA,AMR,FLAC,APE
Image File Format JPEG,BMP,GIF,PNG,GIF
E-book TXT,PDF,HTML,EPUB,UMD
FM Radio Yes, earphone needed
Earphone Port 3.5mm
Card Extend Support TF card up to 32GB extended
Camera Dual Cameras, Front Camera 8.0MP, 88°wide angle, 4P lens , ƒ/2.4 aperture, support Intelligent beauty; 16.0MP back camera, Dual ISP Image chips, 5P lens, ƒ/ 2.0 aperture, Blue glass Infra-red filter, dual 450mA High kinetic energy smart flashlight, support face recognition ,real time HDR mode, panoramic view, burst mode and beauty face function
Cubot X16 Mobile Phone General:
Data transfer OTG/USB/Bluetooth4.0
Mobile internet WAP/WIFI
Phonebook 1000
Message SMS/MMS
Input Handwrite/Keypad
TV No
GPS Yes, built in, also support A-GPS
JAVA No
WIFI Yes, 802.1.1 b/g/n
Bluetooth Bluetooth 4.0
Infrared Port No
OTG Support
Multi-Touch Yes, 5 points touch
Battery 2500mAh Li-polymer battery
Certification CE ROHS WEEE MSDS
Sensors: G-sensor, Light sensor, Distance sensor, Accelerometer, Smart "HOME", Air Control
Other Feature Only 6.2mm, HotKnot, OTG, Cast screem, Gesture Control, Auto-start-managenment, Date-Protection, Mobile anti-theft, Battery saver, OTA update, Smart home key
Language English, Japanese,Bahasa Indonesia, Bahasa Melayu, Catala, Cestina, Dansk, Deutsch, Espanol, Filipino, France, Hrvatski, Italiano, Magyar, Nederlands, Polski, Portugues, Romana, Slovenscina, Suomi, Svenska, Vietnamese, Turkish, Greek, Bulgarian, Russian, Serbian, Ukrainian, Hebrew, Arabic, Hindi, Bengali, Hindi
Thai, Korean, Traditional/Simplified Chinese
Cubot X16 Size: 143.4 x 69.4 x 6.2mm
Cubot X16 Weight: 150g
Cubot X16 Mobile Phone Accessories:
1 x USB cable
1 x Charger
Lieferumfang:
Das Gerät kommt in einer goldenen Verpackung daher welche einen guten und soliden Eindruck macht.
Auf der Packung selbst sind ZWEI IMEI Nummern angegeben.
Nach dem Öffnen findet man folgendes vor:
- Das Gerät selbst
- USB Kabel
- Lader mit EU-Stecker
- Hartplastik Case(wurde direkt entfernt, macht keine guten Eindruck und hat bereits einen kleinen Kratzer verursacht.
- Quick Start Guide - also kleine Anleitung
- Displayschutzfolie
- Tool zum Entfernen des Sim Trays
Ersteindruck:
Muss sagen ich bin wirklich beeindruckt von dem Gerät.
Es fühl sich wirklich sehr hochwertig an, die Rückseite ist aus Glas.
Das Display soll von JDI sein und liefert ein gestochen scharfes Bild mit einer FHD Auflösung und 2.5D Displayrand.
Auf der linken Seite des Geräts befindet sich der SIM Tray, welcher Platz für 2 SIM Karten (Nano +Micro) oder aber Nano SIM Plus Micro SD Karte bietet.
Der Klinkenstecker befindet sich oben am Gerät.
Auf der rechten Seite ist die Lautstärke Wippe und darunter fast mittig der Power Button.
Auch hier alles sehr schön verarbeitet. Hier wackelt nichts und raschelt auch bei heftigem Schütteln nichts.
Unten befindet sich der USB Anschluss sowie etwas versteckt zwischen Rahmen und Display das Mikrofon.
Der Lautsprecher befindet sich leider auf der Rückseite.
Liegt das Gerät zum Beispiel auf dem Tisch, ist die Lautstärke des Geräts also vermindert.
Apropos Lautsprecher, auch diesen würde ich als "Okay" bezeichnen. Kommt in etwa an den Lautsprecher des Nexus 5 ran.
Bei maximaler Lautstärke ist kein knarzen oder verzerren zu hören.
Kamera:
Hauptkamera Sensor: 13 MP Omnivision OV13850 f / 2.2 + Dual Flash
Frontkamera Sensor: 8MP Omnivision OV5670 f / 2.8
Hier kann ich bisher noch keine Aussage machen, da ich bisher immer nur in dunkler Umgebung war wenn ich mal Zeit hatte und somit bisher keine Fotos damit gemacht wurden. Dies werde ich noch nachholen und Fotos anhängen
ROM:
Gleich nach dem ersten Starten wurde ich mit einem OTA Update begrüßt (Stand 28.10), welches ich direkt eingespielt habe.
Die Rom selbst ist nahezu Stock und läuft wirklich sehr gut und flüssig.
Es sind nach dem Update knapp 12GB von 16GB verwendbar.
Nach dem Boot und laden einiger Apps sind noch rund 1,2GB von 2GB Ram verfügbar.
- MicroSD Karte wurde meine 64GB Karte von Samsung ohne Probleme erkannt. Offiziell werden nur Karten bis 32GB unterstützt
- Bluetooth funktioniert ebenfalls ohne weitere Probleme. Konnte mich sowohl mit der FSE im Auto als auch zu sämtlichen Boxen etc. erfolgreich verbinden und es gab bisher keine Verbindungsabbrüche.
- WLAN ist ebenfalls stabil. Leider wird hier nur 2,4 Ghz unterstützt
- Auch GPS funktioniert sehr gut mit dem Gerät ( Glonass und Baidu vorhanden)
Fix hat unter freiem Himmel keine 20 Sekunden gedauert, Genauigkeit bei 2 Meter und ca. 17-20 Satelliten in Sichtweite
- OTG Funktionen werden alle unterstützt
- Double tap 2 wake ist vorhanden
- Telefonie klappt auch wunderbar, Gesprächspartner verstehen mich sehr gut(besser als beim Nexus ), nichts verzerrt oder metallisch dumpfer Klang beim Gegenüber.
LTE Bänder 1,3,7 und 20 werden Unterstützt. Empfang besser als Nexus 5 bei gleichem Netz selbstverständlich
- Akku misst wie gesagt 2500MAh (laut Hersteller), nach 2 Tagen Benutzung möchte ich mich nicht zuweit aus dem Fenster lehnen, über den Tag kommt man aber definitiv.
Fazit:
Alles in Allem bin ich wirklich sehr zufrieden und muss sagen der Spontankauf hat sich definitiv gelohnt.
Erst recht, da ich für das Gerät lediglich 89€ Haustürpreis bezahlt habe.
Spiele sind mit dem Gerät nicht vorgesehen, von daher reicht mir die Power der CPU vollkommen aus.
Optisch erinnert es ein wenig an mein ZTE Nubia Z9 mini
Mir persönlich fehlt jetzt nur noch der Root Zugriff, hoffe mal da kommt noch was.
Bisher habe ich nichts funktionierendes finden können.
Das Cubot X16 wird nun mein Motorola Moto G (1 Gen.) ablösen.
Pros:
- Stagefright Patch bereits integriert
- guter GPS Empfang
- OTA Updates
- Haptik und Verarbeitung sehr gut, fühlt sich hochwertig an
- sehr dünn 6,5mm
- Notification LED vorhanden und konfigurierbar (grün, blau, rot)
Cons:
- bisher kaum Zubehör erhältlich
- CPU nicht für Gamer gedacht
- DUAL SIM Betrieb nur möglich wenn man auf SD Karte verzichtet
- bisher kein ROOT möglich
- Akku nicht wechselbar
- da beide Seiten aus Glas, sehr Fingertapser anfällig
- Softkeys sind nicht beleuchtet
Zum Schluss noch einige Screenshots:
Wenn Fragen sind, bitte einfach stellen
Grüße GDI
Model: CUBOT X16
Brand: CUBOT
Cubot X16 System:
OS: Android 5.1
GPU: Mali-T720
Cubot X16 Screen:
Earphone Port 3.5mm
Phonebook 1000
Message SMS/MMS
TV No
JAVA No
Infrared Port No
OTG Support
1 x USB cable
1 x Charger
Lieferumfang:
- Das Gerät selbst
- USB Kabel
Ersteindruck:
Kamera:
ROM:
Fazit:
Pros:
- guter GPS Empfang
- OTA Updates
- sehr dünn 6,5mm
Cons:
Grüße GDI
