Root für MT(k) 65xx Handys
Der Filename des File auf der Karte muss unbedingt so anfangen: recovery*.img! Dann wird es auch erkannt.
Habe mir die Logfiles angeschaut...
sieh für mich so aus, als würde die Komunication über den Treiber irgendwie nicht richtig zustande kommen.
11/29/13 14:15:51.578 BROM_DLL[1328][6644]: SyncWithDA(): ====== wait for security pre-process ====== (FlashToolLib/sv5/common/generic/src/flashtool_api.cpp:872)
11/29/13 14:16:11.593 BROM_DLL[1328][6644]: ERROR: DA_cmd::ReadData(): Retry(183): ReadComm(0/1): exceed timeout 20000 ms, retry 183 times fail!, total=(0/1). (FlashToolLib/sv5/common/generic/src/da_cmd.cpp:492)
11/29/13 14:16:11.593 BROM_DLL[1328][6644]: ERROR: FlashTool_Connect(0x059ED5D8): SyncWithDA(): fail! (FlashToolLib/sv5/common/generic/src/flashtool_api.cpp:961)
11/29/13 14:16:11.593 BROM_DLL[1328][6644]: ERROR: FlashTool_Connect(0x059ED5D8): fail! "S_FT_DA_NO_RESPONSE"(4001). (FlashToolLib/sv5/common/generic/src/flashtool_api.cpp:1014)
11/29/13 14:16:11.796 BROM_DLL[1328][6644]: com_sentry::Close(\\.\COM19, 0000298C): OK! (FlashToolLib/host/windows/com_sentry.cpp:650)
11/29/13 14:16:11.796 BROM_DLL[1328][6644]: com_base::~com_base() m_hCOM(FFFFFFFF) (FlashToolLib/host/windows/com_sentry.cpp:116)
11/29/13 14:16:11.796 BROM_DLL[1328][6644]: ERROR: FlashTool_Connect_Ex(0x00000000): fail! "S_FT_DA_NO_RESPONSE"(4001). (FlashToolLib/sv5/common/generic/src/flashtool_api.cpp:1289)
11/29/13 14:16:11.796 BROM_DLL[1328][6644]: ERROR: FlashTool_Disconnect(): invalid arguments! *p_ft_handle is NULL (FlashToolLib/sv5/common/generic/src/flashtool_api.cpp:1709)
11/29/13 14:17:04.125 BROM_DLL[1328][7532]: DA_GetInfo(): DA_HANDLE->rwlock: READ_LOCK ... (FlashToolLib/host/windows/rwlock.cpp:407)
11/29/13 14:17:04.125 BROM_DLL[1328][7532]: DA_HANDLE(0x059DE890): DA("E:\Save\Handys\China-Handys\S4\6577\SP_Flash_Tool_v3.1320.0.174\SP_Flash_Tool_v3.1320.0.174\MTK_AllInOne_DA.bin"): m_header={ "MTK_AllInOne_DA_v7.1320.0.0.983", ver(4) }, sizeof(DAInfo_ST)=4428(0x0000114C), m_default_start_addr(0x40000800), m_flu.m_buf(0x0E0F0020), m_flu.m_len(0x0012E0BC)=1237180. (FlashToolLib/source/common/handle/src/flashtool_handle_internal.cpp:5925)
11/29/2013 14:16:30.203 FlashTool[1328][7532][DEBUG]: OperationIndicator::SetDADLAttr(): is_da_dl_all_(true), is_da_high_speed(false), is_da_dl_without_bat(true), is_da_dl_auto_detect_bat(true).(.\OperationIndicator.cpp,128)
11/29/2013 14:16:30.203 FlashTool[1328][7532][DEBUG]: ERROR: OperationIndicator::QueryDADLHint(): da_dl_type(??) error, could not find DA download hint!(.\OperationIndicator.cpp,98)
11/29/2013 14:16:30.203 FlashTool[1328][7532][DEBUG]: OperationIndicator::SetDADLAttr(): da_dl_index(6), da_dl_hint_().(.\OperationIndicator.cpp,133)
Vielleicht hat noch ein anderer eine Idee.
Werde noch ein biss'l recherchieren. Dazu benötige ich aber Zeit. Vielleicht melde ich mich heute Abend noch einmal.
termite99
habe, wie von dir geschrieben, deine UNIVERSAL5410_recovery_131129-120606.img in recovery_131129-120606.img umbenannt. Trotzdem findet M-Uncel diese nicht.
termite99
jetzt hat er diese gefunden. Und jetzt einfach drauf klicken und es sollte funktionieren? Was ist eigentlich, wenn es nicht funktioniert. Habe ich dann einen Briefbeschwerer ;) ?
nein, es wird nur das recovery.img eingespielt. Hat für die normale Funktion keine Wirkung. Aber es ist Dein Handy ich kann nur empfehlen und der liebe Gott bin ich nicht:)
termite99
Mach daraus mal recovery.img
Und dann mal mobileuncle starten.
Zeigt mobileuncle beim start ober links Root oder Unroot
Ja, steht ROOT. [DOUBLEPOST=1385762956,1385762694][/DOUBLEPOST]
OK. Draufgeklickt und er startet durch.
Dann MTKDroid gestartet und unten links ist immer noch blau.
Lt. Root Checker Results: Congratulations! The device has root access!
Zu Deinem Verständnis:
Wir habe jetzt lediglich ein CMW-R Recovery versucht zu installieren. CWM-Recovery hat nicht mit root zu tun.
Jetzt lass das Handy verbunden und Drücke mal unten im Droidtool auf reboot und wähle die Option in ...recovery. Dann werden wir sehen, ob er es tut.
drücke mal kurz den Powerknopf... und wenn es nichts tut. dann einfach im Droid wieder auf "reboot"...
Ist für mich keine große Überraschung. Solange es sich unseren Flashversuchen wiedersetzt....
Machen wir Schluss für heute. Mal eine Nacht drüber schlafen. Vielleicht bekommen wir das auch mittels adb und fastboot hin.
termite99
Alles klaro.
Denke auch, das wir für heute Schluss machen.
Du hast ja heute auch schon so snderen geholfen. Irgendwann muss man mal den Kopf wieder freibekommen.
Wenn wir es morgen nicht hinbekommen sollten, macht nichts, da ich am Sonntag in der Früh für 5 Tage in den bayrischen Wald (Bodenmais) fahre.
Können wir ja dann danach weiter machen.
Bis denne
termite99
Hi G3mob,
3.1 kann leider nicht funktionieren, da im Recobvery-menue die Möglichkeit:
install zip from sdcard nicht vorhanden ist. Es muss erst noch ein vernünftiges CWM geflasht werden.
Aber danke.
Bevor ich die Augen schließe, das war das Ziel. Aber da müssen wir erst mal das recovery drauf bekommen.
closebor
