Elephone P3000 - MT6582 MT6290 5" HD FDD-LTE WCDMA dual sim 1GB Ram 8GB Rom 3150mah 5/13MP Cams
J
johndebur
Neues LTE Handy von elephone. Das Handy ist angeblich Ende Juli erhältlich.
http://www.elemobiles.com/p3000.html
支持FDD-LTE的Elephone P3000将于7月尾发布 mtksj
Support FDD-LTE's Elephone P3000 will be released in late July
MTK 4G launch the program, largely for the benefit of small brands and major brands do export in power MediaTek 4G solutions, these vendors can lower costs to enter the 4G market, the introduction of the use of MTK 4G chip terminal products .
Elephone text called elephant phones overseas markets in recent years, the products are designed for the next big trend 4G elephant upcoming new 4G phones, this product is Elephone P3000.
Many elephants phone Elephone number of products, a variety of product design more features, new P3000 is a very personal look at the new machine. The most eye effect absorption machine where it is the main camera, the entire rear camera designed to become part of a circle, very chic styling, reminiscent of the promise is not difficult to remember 1020, down from 13 million pixels respectively main camera, lights and fingerprint sensor (P3000 can support fingerprint identification function). The aircraft still slim enough thickness, thickness of about 7.6mm or so, there is a black and white colors.
The phone mainly for overseas users, so you can support FDD-LTE 4G standard, compatible with WCDMA and GSM networks, and has dual SIM card slots support dual card dual standby, using the latest MediaTek MTK6582 quad-core + MT6290 solution. In addition to the aircraft as well as five inches OGS 720P resolution screen and a full-fitting 1G RAM +8 G ROM memory, 500-megapixel front camera self-timer, built-in battery capacity of 3150 mA.
Elephone P3000 and we've introduced a variety of export machine, like, the first foreign launch time this month.
HabiXX
Die Spezifikation klingt wirklich gut. Hat sogar die begehrte LTE 800er Frequenz! :)
Anscheinend gibt es das P3000 schon bei Banggood
http://www.banggood.com/Elephone-P3000-5-inch-4G-LTE-MTK65826290-1_3GHz-Quad-core-Smartphone-p-944865.html
aber nur Schneckenpost?
Bei Efox-Shop kann man es noch nicht kaufen
Hongkongeek hat es anscheinend auch auf Lager:
http://www.hongkongeek.com/en/android-smartphones/6197-chinese-smartphone-elephone-p3000-4g-android-44.html
Da ist es zwar etwas teurer, aber dafür ist DHL günstig und man bekommt die Steuern wieder erstattet.
pengonator
Wenn es zu kaufen gäbe dann hätte es auch Efox. Die geben es ja nicht umsonst als Ausverkauft an. Elephone hat ja für's P3000 als Erscheinungstermin Ende September genannt und das ist ja etwas dehnbar....
HabiXX
Toll! Die Chinesen ... wieder mal ein leidiges Thema mit "auf Lager"
Aber danke für die Info.
Wirst du dir eins bestellen?
MTK
Ja ich werde wohl eins bestellen, allerdings warte ich auf das P3000s wegen NFC.
Eventuell wird es aber auch das Kingzone N3 .
LTE benötige ich nicht da ich für mich keinen Nutzen darin sehe.
UMTS reicht mir u. zusätzlich einen LTE Vertag abschließen dazu habe ich keine Lust u. kostet zusätzlich Kohle .
guesa
gibt es denn irgendwo schon ein BIld von der Innenseite? würde mir gern mal die Größe des Akkus anschauen...
HabiXX
Ein MTK6582 Quad Core kombiniert mit einen 3150 mAh Akku... der müsste ja ewig halten...
War ich schon bei meinen Honor 3c voll zufrieden und der Akku hatte "nur" 2300 mAh
pengonator
Nur vom Bild her meinst Du erkennen zu können ob da der Akku der da rein soll nicht die angegeben Kapazität hat @guesa??? :scratch_one-s_head: Schau Dir mal die Specs von dem P3000 bzw. P3000s an, die sind beide nicht die dünnesten Phone: Dimensions: 145*72*8.9mm . Da kann die Akkukapazität schon sehr nahe an der Herstellerangabe liegen. Sobald es die beiden Phones gibt kann man da erst eine verlässliche Aussage machen. So ist das nur Kaffeesatzleserei.
MTK
Seltsam ist nur, dass beim Elephone G5 mit 5,5 Zoll nur ein 2550 mAh Akku mitgeliefert wird . u. beim Elephone G6 mit 5" (also wie das P3000)
ein 2250 mAH Akku
pengonator
Das G5 (5.5") hat einen 2550mAh Akku, das G6 (5") einen 2250mAh Akku, das P3000 (5") einen 3150mAh Akku wie auch das P3000s. Sind alles Angaben von der Elephone-Homepage. Das G5 ist aber auch nur 7.5 mm dick und das G6 7.8 mm. Da sind beide LTE-Phones von Elephone über einen Milimeter dicker. Daher passen auch die stärkeren Akkus beim P3000 und P3000s.
