Erste Erfahrungen Leeco LeTv 2 X527 mit B20
Zenja
Zenja
RR bringt die finale Nougat Version heraus. Hoffentlich macht das Team weiter zu Android 8.x .
Hi guys
Today we will be releasing the final builds for Nougat.
We apologize for the delay as September patches took a bit too long to be merged as well as team members being busy.
Please note that these final builds may take some time to be up on the official download page.
Version will be bumped to 5.8.5
Changes and features are as following :-
Merged September Security Patches
Added PA color engine
Improved theme compatibility with color engine
Improvements to pocket mode
Many device specific changes & fixes (depends on your maintainer)
Updates from LineageOS
This marks the end of Nougat for RR
Thank you all for your support and hope you enjoyed the builds we have provided up till now.
Maintainers Please Note
Please put the "final" tag at the end of your build (its included in your build script)
But What about O? When will it come?
Honestly speaking . Can't say as of now but we predict towards the end of December since there have been massive changes and team members are busy with their daily jobs . Rest assured , O builds will come in time but to give an ETA is not possible .
Downloads (will be available soon depending on your maintainer)
https://sourceforge.net/projects/resurrectionremix/files/
Thank you ,
Have a great weekend
See you next time on Android 8.0
Regards
Team Resurrection Remix
http://downloads.resurrectionremix.com/
Kaulquapp
ehemals Zelda1980
Selten Handys in der Hand, die man in Deutschland kaufen kann seitdem ich seit 2-3 Jahren in China shoppe. Hatte das Samsung J3 zum einrichten hier was preislich dem X547 gleich kommt, und von der Verarbeitung und Geschwindigkeit empfand als den allerletzten Rotz im Vergleich zum Leeco .
Hallo Zusammen,
ich hab derzeit ein kurioses Problem mit meinem X527.
Wenn ich unterwegs bin kommt es recht häufig vor dass ich für beide SIMs die PIN eingeben muss. Vor allem auf der Arbeit muss ich teilweise alle 5 Minuten die Pins eingeben. Zu Hause gibt es keine Probleme.
Ich habe schon ein bisschen gegoogelt und es gibt evtl. ein Zusammenhang mit den mobilen Daten. Macht auch Sinn, da ich zu Hause ja im WLan bin.
Hat da schon jemand etwas von gehört?
Vor allem ist das genau mit meinem Umzug aufgetreten, in Sachsen war alles ok. Aber kaum bin ich in NRW, spinnt das Ding...
Jetzt muss ich mitten im Betrieb, den PIN beider SIMS eingeben. Da es ja immer beide Karten betrifft, müsste es ja ein Softwareproblem sein.
Das ist jetzt wirklich nervig.
Kaulquapp
ehemals Zelda1980
Habe 2 Simkarten mit O2 als Netzbetreiber, und denke der hat bei mir manchmal neu eingeloggt weil hier eine Basisstation hin ist von O2. Jetzt rennt wieder gehabt.
Habe seit gut 2 Monaten
MIUI 8 for LeEco Le 2 ,Current Beta Version: 7.7.6
https://forum.xda-developers.com/le-2/development/miui-8-foe-le-x52x-t3640067/page18
, rennt so gut das ich ungern bzw. im Zwiespalt bin die MIU 9 zu versuchen. Die Kamera rennt, der Akku und navigieren per Rad (Komoot) oder Auto (Navigion) rennt !
Was heißt denn hier?
Bin derzeit in Duisburg, habe auch zwei SIM Karten von O2, eine davon über mobilcom. Das Problem ist nur in NRW, in Leipzig oder Bayern läuft alles wie gehabt. Hab eigentlich auch 4G in der Anzeige, aber es läuft extrem langsam.
Mein Ipad mit der O2 Sim macht keine Probleme...
Wie kann ich das v.a. lösen das Problem, ich bin nicht errecihbar, bekomm noch nicht mal ne SMS als benachrichtigung dass jemand versucht hat an zu rufen.
oskaliope
