J
johndebur
Bei der chinesischen Zulassungsbehörde ist ein neues Meizu Handy aufgetaucht, angeblich mit 4x optischem zoom. Ob das so alles stimmt muss sich erst noch zeigen
疑似魅族MX5现身工信部:竟支持4倍光学变焦!mydrivers
Meizu suspected MX5 appeared MIIT: actually supports 4x optical zoom!
http://news.mydrivers.com/1/431/431533.htmFollowing yesterday charm blue Note2 release, today we are on the Ministry website found a new machine Meizu (issuing date of May 22), the two models are: M575M and M575U, both exactly the same specifications, respectively compatible mobile 4G, Unicom 4G version. With our judgment, it is likely that Meizu new flagship MX5!
From the Ministry of Information website, the machine's screen size is 5.5 inch measurements, 146x74.6x7.9mm, weight 147g. In contrast, MX4,5.36 inch, 144x75.2x8.9mm, weight 147g; MX4 Pro, 5.5-inch, 150.1x77x9.0mm, weight 158g.
From this perspective, this new machine thinner body, the width has also been reduced, it should feel better.
Other configuration, the same resolution and MX is 1920x1080, screen material into the AMOLED, equipped with 2.3GHz eight-core processor (expected to MediaTek's Helio X10 MT 6795, with the same music as 1 Pro), 3GB RAM, 16GB body storage 300 million front +2000 million rear camera, does not support micro SD card expansion.
The above configuration expected, but supports "4x optical zoom" a completely unexpected . Currently, the most mobile phones are used in the digital zoom, by taking the basic, and even changed to the telephoto end, the effect is appalling. Its principle is to use software to an optical image on the photosensitive member using a mathematical method of interpolating zoom, zoom higher the ratio, the more severe distortion, this little experience when we shoot more distant objects using a mobile phone is particularly evident.
The optical zoom lens is adjusted by the scene of an optical distance, depth of field, well as long as the quality of the lens, it does not substantially affect the quality of imaging.
Previously, only the Samsung Galaxy S4 Zoom this wonderful phone only provide optical zoom, it appears that Meizu is really quite the fight to take pictures.
Now through the network license, we do not expect it will see after this new machine.
deshalb hält sich meine euphorie zurück. wobei es technisch sehr gut aufgestellt ist.
