Meizu MX5 (M575U) - MT6795T 5,5" Amoled WUXGA 3GB Ram 16GB Rom 3/20MP Cams optischer Zoom 3150mah
J
johndebur
Bei der chinesischen Zulassungsbehörde ist ein neues Meizu Handy aufgetaucht, angeblich mit 4x optischem zoom. Ob das so alles stimmt muss sich erst noch zeigen :)
疑似魅族MX5现身工信部:竟支持4倍光学变焦!mydrivers
Meizu suspected MX5 appeared MIIT: actually supports 4x optical zoom!
Following yesterday charm blue Note2 release, today we are on the Ministry website found a new machine Meizu (issuing date of May 22), the two models are: M575M and M575U, both exactly the same specifications, respectively compatible mobile 4G, Unicom 4G version. With our judgment, it is likely that Meizu new flagship MX5!
From the Ministry of Information website, the machine's screen size is 5.5 inch measurements, 146x74.6x7.9mm, weight 147g. In contrast, MX4,5.36 inch, 144x75.2x8.9mm, weight 147g; MX4 Pro, 5.5-inch, 150.1x77x9.0mm, weight 158g.
From this perspective, this new machine thinner body, the width has also been reduced, it should feel better.
Other configuration, the same resolution and MX is 1920x1080, screen material into the AMOLED, equipped with 2.3GHz eight-core processor (expected to MediaTek's Helio X10 MT 6795, with the same music as 1 Pro), 3GB RAM, 16GB body storage 300 million front +2000 million rear camera, does not support micro SD card expansion.
The above configuration expected, but supports "4x optical zoom" a completely unexpected . Currently, the most mobile phones are used in the digital zoom, by taking the basic, and even changed to the telephoto end, the effect is appalling. Its principle is to use software to an optical image on the photosensitive member using a mathematical method of interpolating zoom, zoom higher the ratio, the more severe distortion, this little experience when we shoot more distant objects using a mobile phone is particularly evident.
The optical zoom lens is adjusted by the scene of an optical distance, depth of field, well as long as the quality of the lens, it does not substantially affect the quality of imaging.
Previously, only the Samsung Galaxy S4 Zoom this wonderful phone only provide optical zoom, it appears that Meizu is really quite the fight to take pictures.
Now through the network license, we do not expect it will see after this new machine.
http://news.mydrivers.com/1/431/431533.htm
s_94d72e119125467da3b5d0400a8940bf.jpg s_839ae8a8e483478ea980834c84e97f5c.jpg s_067163daf11440fa8143314aecfc17d5.jpg s_d0d55634b88e4a04b2e9c6353e4885b9.jpg s_f65fe28425f84542bc76b13f9822b74e.jpg
J
johndebur
Kommt angeblich im August und soll angeblich 1999 yuans (186€) kosten , wenn es stimmt.
Hat anscheinend doch einen MicroSD Karten slot? Naja mal abwarten :)
魅族MX5抢先上手视频!金属机身来了 mydrivers
MX5 video Meizu first to get started! Metal body comes
After the photo appeared in the Ministry of Industry, to get started now Meizu MX5 larger HD video and also the first time out of real machine appearance, configuration information at a glance!
From the video, the Meizu MX5 for the first time using a metal cover, and use a three-stage design, and the current mainstream metal back cover design is basically the same way, except that the antenna is very narrow bar. In addition, the phone is equipped with a new round the waist Home button, support for fingerprint identification. Another new feature is support for 5V, 9V, 12V (2A) third gear high-voltage fast charging scheme, even if the battery capacity has reached 3150mAh, should also soon full.
Other configuration and yesterday in the Ministry of Industry to see essentially the same, measurements of size 5.5 inches, 146x74.6x7.9mm (much thinner body) and weighs 147g. Phone screen 5.5 inch, 1920x1080 resolution, screen material into the AMOLED, equipped with 2.3GHz eight-core processors (MT6793), 3GB RAM, 16GB body storage, 3 million pre-+2000 million rear camera, maximum support 128GB micro SD card slot, battery capacity 3150mAh. In addition, MX5 running the latest Android 5.0 is based Flyme 4.5.
Another major highlight, MX5 will support 4x optical zoom, which made mobile phones, it is also a rare one.
According to sources, MX5 will be officially released in August.
Meizu first to get started video
http://news.mydrivers.com/1/433/433273.htm
Thus, MX5 1999 元, MX4 1499 yuan, charm Blue Note 2 799 million, Meizu basically completed a new round of layout, if there is a price cheaper charm blue 2, all the better.
Video:
Code:
http://v.youku.com/v_show/id_XMTI1NDc3ODcxMg
faema
Ein Meizu mit SD Slot? Da könnte ich ja direkt hellhörig werden... :grin:
Leider nicht so hübsch, wie das MX4... Aber sonst sehr interessant, das phone!
J
johndebur
Angebliches benchmark Bild vom Meizu MX5. Ist irgendeine chinesische benchmark app, die Zahlen sagen ja da nicht viel aus. Zumindest ist ein MT6795T verbaut, also gibt es wieder T Versionen bei Mediatek.
魅族MX5处理器确认 搭载helio X10高频版 mtksj
Meizu MX5 confirm equipped helio X10 processor frequency version
Charm Blue New Products NOTE2 forefoot before listing, Meizu MX5 information began in the network of fermentation, the Ministry of advance "generous" leaked Meizu MX5 appearance, configured, the remaining question seems to be only Meizu MX5 release date and price a.
The network came to use Meizu real machine MX5 video release of information display, MX5 equipped strange "MT6793" processor, which is obviously the presence of a clerical error, MediaTek and do not have this type of product, the machine before running sub information confirmed Meizu MX5 is built MTK MT6795 / helio X10 processor, and an upgrade version.
Master Lu V6.0 from Meizu MX5 evaluation data show that the aircraft carrying the SOC recognized as MediaTek MT6795 / helio X10, and, MX5 adopt MTK6795 main frequency 1 is higher than the first episode of HTC series and music, frequency of 2.3GHz, which is MT6795 Turbo version, higher primary frequency also means a better physique, a better performance must.
Ministry of configuration specifications and consistent public memory, resolution, etc., Meizu MX5 has 3GB of memory on storage space and 16G 5.5 inch display with a resolution of FHD level, equipment 5000000 front and 20 million pixel camera, in addition, The machine will run Android 5.0 system (Flyme), networks Unicom / mobile two versions.
F
Frog1337
sieht sehr sehr geil aus... wenn der preis so stimmt
die angaben soweit wahr sind... vllt warte ich einfach auf ein neues handy und verballer mein geld erstmal in italien :grin:
johanna123
ich kann meizu nur empfehlen. im vergleich zu anderen wirklich super schönen china handys, mehr schein als sein, stimmt hier einfach alles. lieber paar euro mehr ausgeben und ein rundes gerät bekommen.
es klappt von anfang an einfach. war ich vorher nicht gewohnt. rooten , ein häkchen reicht. die marke hat unheimlich viel potential. ich denke xiaomi und meizu tun sich nichts.
glaube aber nicht das das mx5 günstiger für uns wird als das mx4pro. sieht ja so ähnlich aus.
Squizzy
ich lese aktuell unglaublich viel von einem verbuggten flymeOS :( deshalb hält sich meine euphorie zurück. wobei es technisch sehr gut aufgestellt ist.
SnowyNight
4.2.8.2 lief super ohne einen Bug bei mir aber nun die lollipop BETA builds haben einiges an bugs eigentlich ist nur der battery drain wirklich schlimm
mrkörnchen
...ab und zu mal hier
Ich bin aktuell auf 4.2.8.2I und muss sagen, dass das die stabilste Version ist, die es derzeit für das MX4 gibt. Bei den A Versionen schmiert mir regelmäßig der PlayStore oder die Google Tastatur ab.
Ansonsten ist der vorinstallierte Browser nicht wirklich zu empfehlen, da wichtige Android Sicherheitslücken dort immernoch nicht gefixt wurden.
J
johndebur
Angebliche Bilder einer Pro Version vom MX5, mit 6" Display oder so. In wie weit die Bilder stimmen, weiß ich nicht.
疑似魅族MX5 Pro谍照曝光 颜值很不错 cnmo
Meizu suspected spy photos MX5 Pro color value is very good
[China News] phone two days before the period of suspected online video MX5 started to attract a lot of the user's eye, and now microblogging has exposed a group of suspected MX5 Pro spy pictures, we together look.
From the photo, MX5 Pro design style with the previous Meizu phone is very different, most notably on the back of a classic arc not, is also equipped with a metal frame, it seems to use a double-sided glass design; the power key and volume keys are still on the right, consistent with rumors MX5. Configuration, allegedly screen is 6 inches, more powerful hardware than the MX5, MX5 appeared together are expected to follow.
From the photos point of view, MX5 Pro as a whole to be more concise, bright and clean. MX5 Pro if so, do you like
SnowyNight
Aber 189€ sind doch sehr sehr wenig für ein MX5 oder? Das MX4 hat ja schon über 300€ gekostet
der preis der direkt von meizu für die china version zählt hat ja ncihts mit usnerem zu tun mit shipping und reseller und und und sind wir dann auch wieder bei 270-300 für die 16gb version
ist bei xiaomi auch nicht anders wenn man die flashsale preise in china nimmt wäre es auch günstig aber letztenendes zahlt man hier eh das doppelte also dann schnell mal anfangs 350-400€ damals für die 16gb version
Barbudo
Mi-Boy [CH]
Da mich das mx5 sehr interessiert stöbere ich im Netz nach den letzten news bezüglich mx5.
In den berichten steht immer als soc mt6793, kann mich mal da einer aufklären ?
Bezüglich diesem soc kann ich nichts finden auch nicht bei Mediatek oder ist das nur ein Schreibfehler ?
J
johndebur
ja den gibt es nicht. Stand auch irgendwo, glaube ich, daß es eine falsche Neuigkeit war. Also wieder Gerüchte und zehnfach von einem blog falsch kopiert, so wie es immer ist :grin: Keine Ahnung, aber bei sowas muss man immer abwarten bis der Hersteller die richtigen Daten bekannt gibt :)
Barbudo
Mi-Boy [CH]
@All
weiss jemand was von einem release date ? einmal hab ich was von Juni, dann ende Juni und 3. Quartal gelesen.
Immer diese Gerüchteküche :)
Edit: aha hab grad weiter oben gesehen johndebur schrieb es soll angeblich im August erscheinen.
