Meizu MX5 (M575U) - MT6795T 5,5" Amoled WUXGA 3GB Ram 16GB Rom 3/20MP Cams optischer Zoom 3150mah
J
johndebur
Sind zwar nur Gerüchte, aber vielleicht kommt ja noch eine Pro Version mit Helio X20 und 6" Display. Kann natürlich auch ein anderes Handy sein? naja mal abwarten.
神秘Helio X20十核手机被曝 传为魅族MX5 PRO?mtksj
Helio X20 mysterious phone was traced to pass 10 core
MediaTek May officially released to the outside world is currently the largest number of cores SOC- Steve force Helio X20 (internal code MT6797), The date of the official announcement of the launch at the end, although this flagship solution is temporarily not available, but because of Helio X20 uses a unique clustering architecture Tri-Cluster III (2 * A72 + 4 * A53 + 4 * A53), with strong performance, Since the release of Helio X20 is expected a lot of friends.
Early industry sources of information, clearly exposed Meizu will be the first vendor using Helio X20. Now there are whistleblowers announced a helio X20 phone's specifications, may be starting to think Meizu Helio X20, most users believe that the emerging mystical MT6797 is the Meizu phone may MX5 PRO.
Broke the news people Leaksfly Recently released news of a mysterious phone codenamed Arrow will be the first equipped with MTK Helio X20 market, from published specifications difficult to see out of, which is owned top with a flagship mobile phone, but did not disclose the aircraft by Which hand.
Symbol Arrow phone will built 10 core processor Helio X20, memory specifications so powerful, as a combination of 4G + 64G, with 20.7 million pixel camera and 8 million pre-camera self-timer, run Android 5.11 system. Screen size is also suction eye, this mysterious phone giant with 6-inch screen with a resolution up to 2K level, and have fingerprint and Force Touch (or some characteristic interaction module) and other features.
The identity of the mysterious new machine, most speculation pointing Meizu MX5 PRO, in addition to there before starting Helio X20 Meizu news, Meizu with MediaTek cooperation should also be increased more and more people believe that the main reason for the aircraft is MX5 PRO one. Since MX4 began Meizu follow a series of products who use the MediaTek solution and has the lead in starting the new SOC, MediaTek by Meizu started branding campaign, Meizu is able to get more resources to support MediaTek, with such a win-win cooperation, Meizu possibility pioneered helio X20 terminal is very high.
However, in the absence of a confirmed, this does not exclude products from other manufacturers may, after all, in addition to domestic Meizu, Lenovo, Jin Li, TCL and other manufacturers also maintain close cooperation between MediaTek.
Whistleblowers also announce the release date of this MT6797 phone market, the aircraft will debut in November this year, in the end is the story behind, or wait for the end announced it.
SnowyNight
Am Anfang ist eh immer alles überteuert, ist bei unserem Handys hier auch so, die ersten bis gingen die letzten Jahre immer am Anfang für 700+ und dann 560 sobald sie überall auf Vorrat sind
Barbudo
Mi-Boy [CH]
Ja OK hast auch wieder recht, hab gerade gesehen gibt auch für 500$ :) mal schauen wo sich die Preise einpendeln.
Barbudo
Mi-Boy [CH]
Weiss einer über das super slow motion bescheid ?
Laut Mediatek wird super slow motion unterstützt ab helio x10 und ab Kamera Sensor Sony imx220.
Beides hat ja der mx5.
Aber in den berichten über das Phone liest Mann es unterstütze nur 720p/100fps.
Ist ja voll lächerlich, Hardware technisch ist doch alles an board für 1080p/480fps.
Finde diese Funktion hätte dem mx5 ein Alleinstellungsmerkmal gegeben, vielleicht kann
es ja durch ein zukünftiges update freigeschaltet werden?
heuchland
eFox Mitarbeiter
Ich habe hier ein tolles Review gefunden, wo im Video auch die Frage beantowrtet wird.
Unboxing
Wir durften das Meizu MX5 bereits austesten und haben auch bereits einige unsere Kunden zugesendet, welche sich bereits auf den Weg zu diesen befindet. Also das Gerät macht schon wirklich spaß. Angefangen mit der schicken Verpackung bis zur Anschaltung des Gerätes. Beim Aufpacken fällt auf, dass es eine wunderbare Einleitung zum MX5 gibt sowie, dass der Adapter sehr groß ausfällt. Nach näheren hin betrachten sieht man, dass diese bis zu 9V aufladen unterstützt. Auf diese Weise lässt sich der 3150 mAh große Akku innerhalb von 90 Minuten vollständig aufladen. Was in der Praxis auch sehr gut funktioniert hat. Das ist schon wirklich toll.
Display
Mit 5,5 Zoll fällt Sie dem Trend aus. Aber nichts destotrotz sitzt dieser sehr gut und bequem in der Hand. Das liegt zum einen daran dass die Ränder sehr schon abgerundet sind und der Display einen großen Platz der Frontfläche einnimmt. Bei einer Auflösung von 1080p bekommt man einen PPI Wert von 401.
Performance
Damit auch alles flüssig und ruckelfrei läuft wurde ein 64 bit MediaTek Helio X10 SoC verbaut. Dieser taktiert bis zu 2.2GHz. Als GPU wurde ein PowerVR G6200 verbaut. Zudem stehen einem gleich 3 GB RAM Arbeitsspeicher zur Verfügung. Somit eignet sich das Smartphone wunderbar dafür um aufwendige 3D Spiele zu spielen und auch die Soundwiedergabe ist einfach astrhein, sodass richtig laune und Spielspaß aufkommt. Auch Filme schauen ist entsprechend ein Genuss auf dem MX5.
Fingerprint Scanner
Der Trend mit dem Fingerprint Scanner wurde hier tadellos umgesetzt. Es funktioniert wirklkich bis zu 99,99%. So macht es auch wirklich Spaß es mit seinem Finger zu entsperren. Zudem ist die Reaktionszeit rekordverdächtig. Laut Hersteller soll es um die halbe Sekunde dauern. Das können wir hier beim Test bestätigen. Dieser funktioniert einfach wunderbar und ist kein Vergleich zum Ulefone, Elephone und wie Sie alle heißen. Selbst das iPhone kann hier einpacken und kommt mit der GEschwindigkeit hier nicht mit.
Kamera
Nicht zu guter Letzt ist die Kamera auch wirklich Spitze. MIt der Kamera bekommt man gestochen scharfe Bilder. Der Autofokus funktioniert sehr schnell. Das liegt daran, dass es sich hierbei um einen Laser Autofokus handelt. Denn hinten unter dem LED befindet sich ein kleiner Laser, welchen man als kleinen leuchtenden roten Punkt wahrnimmt, welcher immer wieder aufleuchtet. Dieser ist für den schnellen Autofokus zuständig. Auch stehen einem diverse Funktionen zur Auswahl, sodass man ausgiebig Spaß damit haben kann. Bei der Kamera handelt es sich um einen Sony IMX 220 welcher bis zu 20,7 MP auflöst. Die Frontkamera löst in 5 MP auf.
GPS
Wofür die chinesischen Smartphones bzw. MTK Prozessoren nicht besonders bekannt sind, ist ein guter GPS zum Navigieren. Doch hier beim MX5 werden wir alle eines besseren belehrt. Denn hier beim MX5 bekommen wir sogar im geschlossenen Raum GPS Empafang und dass gleich 12 in der Stückzahl. Auch wenn diese nur mittelmäßig bis Schwach sind. Anschließend im freien Raum haben wir einen Wahnsinnsergebnis bekommen. Dieser schaut so aus, dass wir 17 gute Empfänge in Form von grünen Balken hatten. Das lässt den Schluss zu, dass man mit dem MX5 sehr gut navigieren kann.
Für Specs und Paramter zum MX5 im Detail schaut auf der Webseite von Meizu vorbei:
http://www.meizu.com/en/products/mx5/spec.html
Weltweit das erste Deutsche Unboxing und Review zum Meizu MX5:
synk
điện thoại Man
Wenn man Musik (in "Top Qualität") über das Phone hört, sind auch 64GB schnell ausgeschöpft. Das haben die sich alle von Apple abgeguckt und soll letztendlich nur den Verkauf der teureren 64 und 128GB Variante ankurbeln.
Bzw. die online-Musikdienste und natürlich den Datenumsatz
beim Provider pushen. ;)
Das Performance-Argument ist übrigens für den Popo, wenn
man direkt dagegen hält, dass man sich ja alles aus der Cloud
zurückholen, bzw. Apps neu installieren kann.
Wie lange soll das denn dauern, im Gegensatz zu einer ratzfatz-
backup-restore-Lösung am Gerät?
Jedem das Seine, aber man kann sich auch jede Abhängigkeit
schön reden. :)
F
Frog1337
Scheint ja kein b20 zu haben
Da Efox so positiv davon redet muss es ja n top Phone sein.
heuchland
eFox Mitarbeiter
ein richtiges review wäre mit lieber :grin: naja egal. Gibt es dann wieder eine HongKong / internationale Version?
Dem stimme ich zu. Aber leider konnt ich nichts besseres auf Deutsch im Internet finden was so nah am Gerät war. Das Video selber fand ich ganz ok, wenn man es für sich selber objektiv schaut und sich die Infos rauspickt. Auch finde ich es toll, dass sich jemand überhaupt die Mühe macht ein Deutsches Review zu erstellen. Im Internet ist ja praktisch alles auf englisch und das finde ich sehr schade.
Von einer Internationelen Version wüsste ich nichts. Laut der Meizu Webseite wird nur unter China Mobiles und China Unicon unterschieden:
http://store.meizu.com/product/meizu_mx5.html#2-10-2
Da in Deutschland nur die Unicon Version funktioniert kann man hier ein ROM herunterladen und auf dem Smartphone packen um es dann anschließend upzudaten, sollte man versehentlich die China Mobiles Version bekommen. Dann funktioniert nämlich beides zugleich:
http://www.flyme.cn/firmwarelist?modelId=45&type=1
J
johndebur
ja aber ist es dann immer noch so , daß dieser bootloader oder was dann gelockt ist ? Das war ja sonst bei der Hongkong Version nicht der Fall.
naja mal abwarten was noch so kommt :)
Constrictor
So toll musst du das garnicht finden, die wollen die Dinger ja auch in Deutschland an den Mann bringen ;). Ist aber trotzdem nett anzuschauen, da hast du Recht.
Gibt's hier eigentlich ernsthafte Interresenten für dieses Gerät (oder Pro)?
sawfish
