Linse77
Hier meine Fehlermeldung:
Validating Application Configuration
Load APP Configuration
COM:3
SAHARA:True
SAHARA:E:\Downloads\Letv\3\Qfil\tmp\prog_emmc_firehose_8994_lite.mbn
SEARCHPATH:E:\Downloads\Letv\3\Qfil\tmp
RAWPROGRAM:
rawprogram_unsparse.xml
PATCH:
patch0.xml
ACKRAWDATAEVERYNUMPACKETS:False
ACKRAWDATAEVERYNUMPACKETS:100
MAXPAYLOADSIZETOTARGETINBYTES:False
MAXPAYLOADSIZETOTARGETINBYTES:49152
DEVICETYPE:eMMC
PLATFORM:8x26
RESETAFTERDOWNLOAD:False
MAXDIGESTTABLESIZE:8192
SWITCHTOFIREHOSETIMEOUT:30
RESETTIMEOUT:200
RESETDELAYTIME:2
FLATBUILDPATH:C:\
FLATBUILDFORCEOVERRIDE:True
QCNPATH:C:\Temp\00000000.qcn
QCNAUTOBACKUPRESTORE:False
SPCCODE:000000
ENABLEMULTISIM:False
Load ARG Configuration
Validating Download Configuration
Image Search Path: E:\Downloads\Letv\3\Qfil\tmp
RAWPROGRAM file path: E:\Downloads\Letv\3\Qfil\tmp\rawprogram_unsparse.xml
PATCH file path:E:\Downloads\Letv\3\Qfil\tmp\patch0.xml
Programmer Path:E:\Downloads\Letv\3\Qfil\tmp\prog_emmc_firehose_8994_lite.mbn
Process Index:0
Programmer Path:E:\X800\X800\X800\QFILX800\prog_emmc_firehose_8994_ddr.mbn
Image Search Path: E:\X800\X800\X800\QFILX800
RAWPROGRAM file path: E:\X800\X800\X800\QFILX800\rawprogram_unsparse.xml
PATCH file path:E:\X800\X800\X800\QFILX800\patch0.xml
RAWPROGRAM file path: E:\X800\X800\X800\QFILX800\rawprogram_unsparse_cuoco.xml
Start Download
Program Path:E:\X800\X800\X800\QFILX800\prog_emmc_firehose_8994_ddr.mbn
Binary build date: May 13 2015 @ 14:41:37
QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files (x86)\Qualcomm\QPST\bin\QSaharaServer.exe -p \\.\COM6 -s 13:E:\X800\X800\X800\QFILX800\prog_emmc_firehose_8994_ddr.mbn 'Current working dir: C:\Users\Linse77\AppData\Roaming\Qualcomm\QFIL
Sahara mappings:
2: amss.mbn
6: apps.mbn
8: dsp1.mbn
10: dbl.mbn
11: osbl.mbn
12: dsp2.mbn
16: efs1.mbn
17: efs2.mbn
20: efs3.mbn
21: sbl1.mbn
22: sbl2.mbn
23: rpm.mbn
25: tz.mbn
28: dsp3.mbn
29: acdb.mbn
30: wdt.mbn
31: mba.mbn
13: E:\X800\X800\X800\QFILX800\prog_emmc_firehose_8994_ddr.mbn
18:49:28: ERROR: function: sahara_rx_data:194 Unable to read packet header. Only read 0 bytes.
18:49:28: ERROR: function: sahara_main:854 Sahara protocol error
18:49:28: ERROR: function: main:265 Uploading Image using Sahara protocol failed
Download Fail:Sahara Fail:QSaharaServer Fail:process fail
Finish Download
UHUFAD
@Cuoco92: Hab vorhin die 13s installiert. Läuft wie immer top. Danke! Allerdings sind mir gar keine Änderungen zur 10er aufgefallen. Kannst du sowas wie ein Mini changelog posten?
hotwebnet
Hallo zusammen, nun habe ich es auch von Efuchs erhalten, ich habe die EUI Version 5.5.011S (Stable) drauf. 5.0.2 ich habe die gleichen Probleme wie alle hier....Cuoco92 Rom soll ja sehr gut sein, aber leider blickt ich hier nicht mehr so richtig durch und die Download von Seite 1 gehen nicht mehr. Kann CUOCO92 nicht in seinem Ersten Beitrag noch einmal alles richtig zusammen schreiben.
TWRP RECOVERY 3.0.0 inkl. Download und Anleitung und sein neustes Rom inkl. Anleitung ich glaube das Handy wird in der nächsten Zeit noch viele User bekommen.
Cuoco92
Hi :)
Ich habe einigen post davor, eine script Datei damit mein firmware auch auf die US Version installierbar wird.
Du findest die 13S firmware hier:
https://www.androidfilehost.com/?w=profile&uid=24533103863137898
Warte bitte bis heute abend (spätestens) da werde ich ein firmware für die US Variante zu Verfügung stellen.
Oder lade die 13s herunter, und BEVOR DU DAS INSTALLIERST , öffne das mit WinRAR und LÖSCHE DEN GANZEN 'FIRMWARE-UPGRADE ' ORDNER.
Das passiert auch nichts
Inviato dal mio Le X820 utilizzando Tapatalk
hotwebnet
Hi :)
Erst einmal eine Frage die hier nicht steht....
ist das....
LETV X800+ Baugleich mit dem LETV LE1 PRO ONE PRO vom Fuchs ????
Vielen Danke für die Info, ich warte dann aber bis heute Abend, ist den auch das TWRP RECOVERY 3.0.0 in deinem Downlaod oder wo bekomme ich das ???, eine Spende ist dir sicher,
So habe jetzt die X800_TWRP_3.0.0.zip gefunden https://www.androidfilehost.com/?w=files&flid=57905....und wie geht es jetzt weiter ??? i....hier steht so viel durcheinander das ich nicht mehr durchblicke... Ich habe die US-Version wie schon beschrieben.....
Wäre echt super wenn du das alles im ersten Beitrag schreiben könntest....dann haben die Leute es viel einfacher....Danke
Mahanga
Ich habe meins (US Version) gestern auch geschossen, jetzt grüßt der Pinguin :popcorm2:
Habe scheinbar etwas falsch (lt. Cuoco`s letzter Anleitung) gemacht...
Vielleicht kannst Du die benötigten US Daten ja stellen, damit wir unbricken können.
Wenn nicht schmeiße ich das Handy die Tage weg, oder schicke es den HongKong Tonis von Efox in Bruchstücken zurück.
Linse77
Solange der Pinguin noch leuchtet, sei froh ;-)
Bei anderen und mir auch leuchtet garnix mehr!!!
L
Lucky 2
Hast du das gamacht.!!!
5) Öffne das mit WinRAR und überschreibe den gesamten META-INF Ordner. Du kannst die auch löschen und die neue kopieren.
6) Lösche der firmware-upgrade Ordner
Vor allem den Schritt 6 dann kann´s doch nicht bricken.
Mahanga
Hast Du schon mal versucht alle drei Knöpfe zu drücken, sprich Volume up+down + Einschaltknopf?
Wenn der Pinguin wenigsten schmecken würde, dann würd ich das Ding auf meinen Weber Grill packen :drink:
Ich hoffe Cuoco92 kann uns Hoffnung machen und bekommt das hin... :feuerwerk:
@Lucky2: Ich habe TWRP Recovery Installer von Cuoco ausgeführt (Flash),
ich war gestern gegen 01:00 morgens zu gefrustet und habe im Delirium scheinbar alles falsch gemacht... (Muss auch eingestehen das ich mich gegenüber vielen anderen im Forum wenig mit der Materie auskenne...)
Jetzt befindet sich das Handy in einer Dauerschleife an-Pinguin-aus-an-Pinguin-
aus.
Die Kollegen aus dem Forum haben mich ja gewarnt, also selber schuld...
L
Lucky 2
Ja mach ich öfters aber bei meinem Lenovo K3 Note .
Cuoco92 hat mir aber auch schon aus der Misere geholfen!
Aber warum musst du alle drei auf einmal drücken??????
Steht doch auf der ersten Seite.
Power Taste und Volume+ gleichzeitig gedrückt halten bis das Smartphone Neustartet und 2 Sekunden nach dem LETV Logo Erscheinung loslassen
So kommt man ins TWRP Recovery
L
Lucky 2
Wünsch euch allen Viel Erfolg !
Wenns einer wieder hinbringt dann Cuoco92:thumb_up:
Cuoco92
Wenn der Pinguin steht, ist alles noch Safe :)
Lade das herunter
Entpacke das auf dem Pc Desktop
Verbinde das Smartphone aufm pc
Starte die Datei X800-TWRP-INSTALLER.exe
Folge die einweisungen und sollst du ins recovery landen.
Sag mir bitte bescheid :)
